A false belief, long held, remains false
1 Million Miles on a Gasser
Idiot drivers
rbattelle
I just thought I'd take a minute to point out that if you think something is true that isn't, it doesn't matter how long you've believed it to be true, it's still false. 2+2=3. 8 is not true, even if your grandfather, great-grandfather, and the King of England all taught you from when you were 2 years old that 2+2=3. 8. It doesn't matter how much physical evidence you can produce that shows 2+2=3. 8, it's still not true.
I find this sort of behavior particularly prevalent with the more senior members of society. For example, my friend's father in law absolutely cannot be convinced that with 2-wire house wiring used to carry both 240v and 120v currents, there will necessarily be a current in the ground line for the 120v circuit.
Why? Because where he works 2-wire is used as feeder wire from the pole. Therefore, it's perfectly acceptable to use as feeder wire for a subpanel which will contain both 240v and 120v circuits.
Doesn't matter what you tell him, or how many facts, or how much electrical engineering you show him, there is no current in the ground line. And even if there is, it must be okay since 2-wire is used to feed the main box.
My father, to this day, is convinced that wind chill effects your radiator and anything else left out in the cold just as much as it effects people. I've never been able to convince him otherwise, ever since his radiator froze up 40 years ago because he was driving too fast on a cold, windy day.
A guy I work with told me that this helicopter is tiny - small enough to fit on a desktop. He would not be convinced he was wrong. As far as I know, he still believes this.
It's a very curious mental habit, and I'd be lying if I said I don't sometimes catch myself falling into the same trap. Diligence is required to ensure you don't cling to false "facts".
So the next time someone tells you you're completely full of it, take a moment to think carefully and logically. Even better, go to your local library or nearby internet-enabled PC and be sure you're right.
This public service announcement has been brought to you courtesy "The Human Fund".
Ryan
Are you telling me that Ford really owns Cummins :-laf :-laf (sorry)
I have a friend that thinks that wind chill does effect other things. We were four wheeling for an entire day and I still could not get him to see it my way :-{} :-laf
My father in law thinks that his daughters car is on it's 3rd power steering pump. When it is on it's 4th. The one it came with he does not count, "you only count the ones that are new. " Why you would not count the one it came with I have no idea! :confused:
Reminded me of an old farmer I knew who I serviced his equipment always drained the coolant from everything and filled it up with missouri river water,along with the sand and dirt that was in it. He thought that it was better than antifreeze because the river never froze up until it was -10 or -20 for a while. Didn't occur to him that the water flows 3. 5 mph year round :rolleyes: Then he thought we were selling bad parts when the water pumps on his brand new tractor only lasted a week. :eek:
LMAO good one :-laf
