A few gauge questions
470hp/925Tq
Changes between 04.5 and 05???
I have an completely stock '04 with the 305/555 motor with 6-speed, and I am thinking about putting some gauges on it using the Autometer Triple In-Dash holder. I am looking at the Autometer Ultralite 0-60 boost, egt, and 0-15 psi fuel pressure with isolator. Is there anybody running this set-up, and how do you like it? Is there a cheaper way to hook up the fuel pressure gauge without buying the filter cap from Genos? Thanks for the help.
Get a tapped banjo bolt from Geno's, and replace the banjo bolt on the injection pump with the tapped bolt, then hook your fuel line to the tapped bolt.
-Tom
I had the same setup and my stock fuel pressure is usually about 7. 5, but I would get the 0-30psi fuel pressure gauge, if you plan on any power mods. My TST will suck it down to 0 on the higher settings, but I am installing a pump that will push 18-19psi at idle. Most of the aftermarket pumps will push over 15psi. Just something to think about.
