Just installed my Jacobs brake and I'm feeling proud of myself. Latest outing with the travel trailer and the exhaust brake was awesome.
But, pulling big hills tells me that I need a larger turbine housing to control the EGTs. I'm thinking a 16cm non-wastegated for about $150 should do the trick. No problem you say? WRONG!
Unlike the Pac-Brake and most other turbo-mounted exhaust brakes, the Jacob's butterfly elbow has a cast flange that bolts directly to the back of the turbine housing. This means that the only housing I can upgrade to is a 14cm WASTE-GATED housing at about $425. The Pac-Brake uses an adapter plate with a v-ring connector rather than the cast flange that the Jacobs uses. Hence, the aforementioned restriction to using the 14cm housing. DOH!
