A-Pillar Removal......SNAP!!!!!
19.5" Rickson wheels and Yokohama tires
Which pyro probes fit pre-turbo?
Ordered an Autometer full pillar 3 gauge pod.
DIS recommends removing the OE A-Pillar and drilling holes where the pods are located for the wiring to run thru.
Pulled the A-Pillar STRAIGHT out and GENTLY per the online instructions and the service manual.
The cheap plastic clips on the A-Pillar are "melted" to the pillar. The metal clips on the truck pillar frame are metal and sort of "barbed". These clips DO NOT want to let go. Snapped both A-Pillar clips trying.
Simple solution was to reattach the plastic clips to the A-Pillar with sheet metal screws. You Won`t be able to see them. The Autometer 3 pod pillar will cover them up.
I noticed per the Autometer instructions that there is a gap at the bottom of the gauge A-Pillar for the wires to pass thru. Not true. Its a flush fit. Drilling holes for the wires thru the OE A-Pillar is a good idea.
Over all the Autometer Pod looks good. I real nice fit to the OE Pillar.
Ran into problems w/ Water Temp gauge. The 6' lead is TOO SHORT. Re-Ordered the 12'lead gauge. The 6' might have made it if I was mounting below the dash. Up on the A-Pillar no way.
Just thought I would pass this along. #ad
Bill R
94 2500 SLT,4X4,5 Speed,3. 54 LSD... . Still looks brand new... .
I did not remove the original A-pillar moulding when I installed my gauge pods. I ran all the wiring and tubing in between the 2 and drilled the holes for the clips while it was in place.
Paul A. Schmidt
95, 4X4, SLT 2500, 5 spd. , 4. 10, 270 hp. ,675ft. lb. TST, AFC spring kit,215hp. injectors, Pacbrake, Walker muffler,
GearVendor O. D.
Eastern PA.
