A-pillar ?
Jacobs Exhaust Brake on 2001 6-speed?
Wix Xtended Drain Oil Filter
I ordered my gauges from Geno's. Recieved Pyro/Boost, Trans temp and waiting on the fuel pressure. My question, I am trying to make sure everything will work before I start tearing into my truck there doesn't seem to be enough clearence between the dash and the current a-pillar. How will the new one work or will I have to do some modifications. Any help will be appreciated.
Thanks
margil
P. S. I forgot to mention that I recieved my EZ today and I could not wait, so I installed it and OH MY GOD. HMMMMM what's next?
I got new apillar 3 gauge with tweeter for mine from Geno's I think is the same on Autometers sells. I took of old one and installed new one and was plenty of room. You did not say if installing 2 or 3 guage pillar but should have plenty of room either way. Hope this helps.
It should be a direct replacement, just stick it on there, may 1 screw to hold it in place, not sure on the newer trucks.
A-pillar
I didn't put mine over the stock pillar, just used it as a replacement. One screw, piece of cake...
Jim
Do a search lots of different ways. I think most take of old and install new and hold in place with 1 screw. Use a screw cover to hide screw available at almost any hardware store. I got my screw cover at Ace not sure what they actually call it. Screw goes through it and a cap flips up and over to cover screw. Like everyone said it is easy. ;)
