Engine/Transmission (1998.5 - 2002) A question about starter contacts for those who have also changed them?
Engine/Transmission (1998.5 - 2002) Injectors
As an after thought I had today about changing my starter contacts the other day I thought about asking our members if you found both old contacts showed wear?
I had my starter on the bench with the contact case on top and after removing the cover I found that the contact on the left to be almost worn through and the other contact had hardly any ware marks. In fact, I now think I should have only replaced the single worn contact and left the other one alone. But, I now have a spare contact. :-laf
What you say? Thoughts/comments please.
PS: I could not see any difference in weight and/or thickness between the old OEM contacts and the new so called "Supersize contacts"
I posted this twice by mistake, sorry.
No! I did not check the brush's. #@$%!
Thanks for the heads up on that one. I don't recall having read here about checking brushes.
I'll add that to the to-do-list.
What the heck. I'm experienced at starter R&R now so it should be a piece of cake to do it again. :-laf
Thanks, Tom
