DF5152 said:Since you have introduced your pumps I believe you have some knowledge about them. can you possible elaberate on the cause of the leak the stock pumps are experiencing and the cure?
Dan
DF5152 said:Thanks for the reply but i was looking for something a little more specific. I find it hard to believe that all the leaking pumps are do to so many potential problems. its probably one problem. bad batch of seals or seal/shaft wear due to lack of fuel, which would cause excesive heat. I was more wondering if there is a specific seal or shaft that is wearing due to lack of lubrication or poor quality. What is your definition of extreme heat? the pumps you are making will they work with the factory lift pump? Is there a specific inlet pressure and flow that works best with them. can you over pressure the pump or bypass in the cp3 and cause damage?
DF5152 said:at 120 psi reliabilty of which pump the fass or cp3? on the pumps you are modifing have there been any issues with wear on any specific part prior to modification?
Diesel Power said:the fass cant keep up with 120 psi and the 40 psi is compleatly safe, no problems that we have seen. !![]()
AEzzo said:I've never been able to find a flow chart on the FASS. How many GPH are we talking about?
Diesel Power said:at the standard 15-20psi the fass 95 will give just about that. the fass 150 is the same, and thats what we use, it would be 150gph or better at 40psi!!. alot has to do with draw down rate @ 40psi it will not draw down much at all, but at 15-20 it can be drawn down to single digits with no problem!!! it is giving more constant volume. :-laf
AEzzo said:The only reason I ask is alot of pumps are rated at free flow. My setup in my truck flows about 70-75 GPH at 15 PSI. Would this be enough to feed one of your CP3's. I realize that additional flow is used for cooling but I have a hard time believing that 150 GPH is needed.![]()
Diesel Power said:you need to understand that the fuel needed to push up to 35,000psi constant are tremendous, if you wish to use your 75gph pump on our cp3 thats fine but dont get mad when you've toasted your pump----we only recomend this because it works, do it right the first time and you will be glad you did. !!! Oo.
AEzzo said:I am trying to understand. But all I've heard from you is a sales pitch. Without flow data everything you say is all but meaningless. I would think you would be able to tell us what exactly is needed in the way of flow. How can you not know exactly what the FASS flows at 40 PSI. I would tend to think the 150 is rated at free flow and would drop off at higher pressure. I'm not trying to start an argument, but trying to learn and make the best decision possible before laying down my hard earned money. To do this I need facts and not a sales pitch. :-laf
Trying to figure out the BSFC of a 600 HP Cummins and I come up with about 70 GPH. Now I added about 30% to figure in cooling flow. I could be wrong but this sounds a little more reasonable.
Maverick said:just put my fuel press fitting in today. after all we read about pressure @ flow or volume changing feed pumps fuel lines fass 95 150, holley whatever you like. look at the feed hole size into the cp3 nomatter what you put to it (fuel) that tiny hole is only going to let so much in. and cranking up the pressure might just introduce more air in the fuel with the stock tank feed lines (tank to pump) but after all that thought i could be wrong.
