A question for guys with Eaton Fuller shifter knobs
Pusher pump install question
What is minimum driving distance?
I was just wondering if any of you guys that have the EF knob also have a Cup Smoothie? I was just about to order one the other day, but had had plans to pick up my Eaton Fuller knob since last Thurs. and was scared it wouldn't fit.
I have a CB mounted upright right in front of my center seat section. Now I can live with having a little difficulty changing channels or adjusting the volume if that cup smoothie with fit with my EF knob. Anybody have any clue if it would fit?
I have a line on more EF knobs if any of you guys would be intrested, drop me a PM and let me know.
It fits just fine for me, no interference with the shifter and the cup smoothie. I have my CB radio mounted right behind the factory cupholder on the passenger side, but I'm not reaching for it often -- the mic has channel change controls, and it likes to live in the leftmost pocket of the smoothie.
-jon-
The only thing I would keep in mind is that the cup smoothie will interfere with the shifter IF you try to lower the armrest from the raised position, or raise it from the lowered position, while the gearshift is in 2nd/4th/Reverse on a 5 spd or 1st/3rd/5th on a 6 spd.
The cup smoothie interferes with my stock setup in these positions, so I can imagine it would do so with the EF setup you mention as well.
HTH.
Duane
01 Ram 4x4 "Brandy"
