Greetings from a FNG I have learned a lot but I have not found any info on how the down pipe is modified for installing the non wastegated 14cm housing on a 93. Do you cut and weld? If so what material is the down pipe constructed from I has the look of stainless.
I have installed the pyro (post turbo my pyro is taken from a aircraft airstart unit and I have not ran across an adapter yet to put it in the exh Manifold)) and boost. I have about 650 to 700 deg when pulling up hills now this is unloaded (No trailer or load) and am seeing about 18 psi of boost. The only pump tweak I have accomplished is turing in the smoke screw in a 1/2 turn and it made a difference at the bottom end I know I need to advance the timing a bit which I will accomplish at work this week it workload allows. I am planning on a set of PODS once I get this housing install finished. Thanks for any input.
