The book says add 1. 5 for pan drop and filter change plus 1. 5 for the regular size Mag-Hytec pan. This put it at the top of the level on the stick hot and in neutral after reverse to neutral to drive lever movements. So the transmission shifted bad and I added another. 5 qt, until it began to shift better. It took another 3. 5 qts. to make it work correctly? I talked to Bill K. and I believe he said 6qts. and that the book was wrong? What have been you other guys experiences with this? Thanks
99-24V-2500-Laramie-SLT-A/T-LSD-355
All Options except cab lights and carpet-Rino- Prime-Loc-Alcoa wheels-Lund cold front-Factory Tows-DSG Electronic Fast Idle-Mag-Hytec transmission Pan+Rear Diff. Cover -Tekonsha Voyager- VA CPC -Rancho 9000-5000 steering stabalizer - BD exhaust brake - Auto-loc - Astroflex autostart -Bill K. T/C and V/B in tranmission -Prime-Loc removed and hanging in garage-Alaska
