A Towing Adventure (long)
Best 5er ????????????
tow package/brakes
Vacation. Trip to Calgary and Red Deer, Alberta from Vernon BC. Starting Vehicle: Dodge Caravan. Result: Calved minivan in Cochrane Alberta. Seriously dead. Solution: Fly home, borrow my old car trailer from its present owner, and drag the POS home with the Turbosaurus to work on it. The turbosaurus is stock (not for long) with Automatic trans. Trailer and load weight was probably about 5300 lbs.
These are my observations.
1. A fuel pressure gauge is a priority! The injection pump is too important (expensive) to leave to chance. I could feel it going flat on some of the hills with my foot in it. Even backfired a few times when I was really into it. The lift pump and fuel system are getting attention as soon as the minivan is repaired and traded off.
2. With 3. 55 gears, 2100rpm @ 70mph is sweet. Nice hum out of the exhaust and runs smooth.
3. Based on that, 4. 10 gears would probably give about 2100rpm @ 60mph. Sure was fun at 70mph though. Kinda fun to blow by the pokeys with a trailer and load in tow. How fast do YOU tow?
4. There is too large a gap between 3rd and overdrive. When on the hills, in third, it really wants to buzz right up there. Sounds even busier when the fan clutch engages. I'm not thrilled with the way it downshifts to 3rd-unlocked then locks up again. A tighter converter would be an asset, as would be a way to get manual control over lockup. Or not lockup. I'm still considering the effect and application of the infamous 'mystery switch'. I'd also consider a manual trans next time. (and this was supposed to be my 'No More Toys!!!' truck!)
5. More gauges. Transmission temp, Pyro, Boost. In that order.
6. More power!!!!!:D:D:D:D:D (All right, mister Glover, get control of yourself. Calm down..... That's better. )
7. I have a Kelsey Hayes hydraulic brake controller that I'm going to install next winter. I used it manually on this trip, with it just laying on the seat beside me. I have it, it works OK; It can be plumbed between the master cylinder and the ABS servo. My second choice would be the Jordan controller.
All in all, it was a good proving trip that allowed me to explore the strengths and limitations of the Turbosaurus, in all kinds of terrain, from the foothills of Alberta, to the steep grades and sharp corners (sometimes at the same time) of the Rockies. Now, if I can just figure out what broke on the POS Caravan so I can get on with the bombing... ... .
For What It's Worth.
Tom
Nice report... the thing about using your Ram is that you find out more info on exactly how YOU want to set up YOUR ram.
The individuality of the way we tow is almost as great as the color we choose.
You might want to re-think you choice of brake controller.
If your truck has any type of ABS your Kelsey-Hayes controller may NOT work!!
If by some chance it does work, your trailer braking will not be adequate, IMHO.
Stranger, thanks for the advice. I've not talked directly to anyone that has actually fitted a hydraulic brake controller to their Dodge truck. I wonder if the reason for going away from the hydraulic controllers has more to do with plumbing brake lines and bleeding brake fluid all over some guy's leather interior, rather than actual performance and compatability. Rate and inertial controllers aren't as labor-intensive to install, either. They install quickly and they're cheap to manufacture (most of them).
Installing a hydraulic controller will make me a test pilot, that's for sure, and I will test the combination carefully to ensure that it works properly and doesn't interfere with the anti-lock system. Although hydraulic controllers are difficult to find these days, I will report the results here.
This truck has rear anti-lock; I've yet to activate it, even when I've tried. The truck is new enough that it should be functional.
It's possible to plumb the brake controller between the master cylinder and the anti-lock controller, where its effect on the system should be minimal. We shall see!
Ideally, Vacuum over hydraulic would be a superior setup, but very few trailers have this. If I only owned and towed one trailer, that's probably what I would use. Electrics are far more universal, however. I was able to plug and go with my old trailer because it uses industry-standard connectors and wiring conventions.
Tom
Info
You have much more info than I.
IMHO, though, when the rear Anti-Lock activates, the pulse rate would be much faster than the magnets can activate; therefore reducing trailer braking to nil.
If I remember correctly (I have been wrong before, just ask any of my EX- wives ;) ), a hydraulically controlled, electrically activated braking system needs steady continuous amperage to operate correctly. Even though the "Gain" may be turned up to its maximum. The lagtime before the pucks hit the disk, grab, then the arm rotates on the anchor and the shoes contact the drum and then start braking is way too long and the ABS has pulsed many times. (Did I say that correctly?)
If you are correct your braking will be jerky at best.
However, if I'm correct I don't think you will feel any braking in a "HARD" stop. In normal stops and braking though it might be alright.
PS. If you are in CA, please be in front of me as I stop for no known reason (Insert HA HA here).
Seriously, I hope you are correct.
I hope I haven't offended, and I don't want this to be taken as a flame.
I've had a rough couple of weeks see post in "Other" about Central, CA mambers
Tommy, 4:10s are 2250 at 70 mph. Good towing story. I pulled 9K from NE Ga Friday. Got behind a Tundra pulling a Jon boat. The guy pulled the slowdown on me a couple of times so that I couldn't keep my speed up to my normal 60 on the 2 lanes. Finally as we were approaching a passing lane (which in Georgia always starts at the bottom of a hill) I pulled into the left lane and the race was on. I beat him to the close down lane and it wasn't because he slowed down. That's the first time since I'd gotten behind him that he had been over 60 mph.
To answer your question on towing speeds, I tow 60-65 on the two lanes (65 when I want it spooled up good tackling a big hill) and 70-75 on the interstate.
