A trail of diesel.....
scratch repair advice
Recall 701,000 Rams ???
I had quite a surprise today- was walking to my truck to get in & go after making a call on a customer and noticed something unusual hanging low by the driveshaft. It was the fuel tank!! The rear support strap had broken and it was hanging on only by the filler hose, diesel was dripping everywhere since I had just filled up the night before. I babied it a couple miles to an auto shop and they ran it on the rack, got a transmission jack under it, and welded strap back together for a temporary fix. Bad news was it broke the fuel tank neck where filler hose attaches so I guess I need a new tank. Does anyone have any suggestions? Might try a salvage yard for a used one. I figure Dodge will be quite proud of new tanks.
Thanks in advance, I'm new to these trucks and the TDR but it amazes me how knowledgable and helpful everyone is!
95 3500 4x4 CC Auto 3. 5
stock for now!
Check out transfer flow.
They have a 54 gal replacement or midship tank. Its aluminum.
1998. 5, 2500, SLT, 24V, 4X4, Auto, 4. 10 towing 35ft. 5er
On Order due May 1. 3500, SLT+, Green/Tan, HO, 6 speed, 4X4, 4. 10, towing package, camper package, E-brakes.
This is the golden opportunity to get the 54 gallon direct replacement tank. There was a thread a while ago about 750. 00 I think. If You need to be conservative check with some body shop on plastic welding you may be able to repair yours?
LOL Rich
20yr Mopar Parts Manager,"June of 2000" 2001 quad cab,2wd,auto,354 LSD rear axle,Raven Magnum 8' cap. Mag Hitech trans pan. Isspro gauges pyro,trans and boost Apillar mount. Amsoil air filter. No muff! N. R. A. member
Go to transfer flow's site. Its on sale right now. 661. 90 Hurry while supplies last #ad
1997 2500 4x4, CC, Auto, 3. 54 LSD, 68K, Everything inc Leather, K&N, 4" BD cat-back, otherwise stock, Isspro Gauges(3), 285/75/16 on Alcola's, RS9000's, Molded Side Steps w/ Ground Effects, Chrome Trim, Canopy, ProFlaps F&R, BedLiner, Aux. Lighting F&R, and tons more.
[This message has been edited by SlyBones (edited 04-13-2001). ]
I just noticed the transfer flow 54 gal is advertised for 98-01 trucks with ext. cabs and long beds. Any reason this wont work on the 97 and earlier trucks, of same size.
