OK rear end gurus . . have a simple question . .
Are the AAM rear ends plug and play? Meaning, is the basic housing the same, and what makes them different is how they are equipped with either SRW or DRW axles/hubs or carrier setup for gearing, ie: 3. 73, 4. 10, etc?
Can you pull a SRW hub assy/and axle and plug in a DRW hub assy/and axle or the reverse?
Seems to me this is possible. Many who want to switch one way or the other could actually do this as a swap or build rather than exchanging the entire rear housings. Both are 30 spline, the basic housing is the same, the actualy end where the hubs bolt up are the same, the rotors are the same, the spring perches are the same and the shock mounts are the same - am I on the right track with this?
CD
CD
