I was going to change the front & rear axle oil in my 06 2500 QCSB 4x4 Diesel. I bought some Lucus synthetic 75-90 lube, but am confused about the fluid level. In issue 66 of the TDR page 55 their is a bulletin about the axle fill holes being in the wrong place and if you fill it to the hole you could overfill the axle, causing foaming. The model on the bulletin is for the 1/2 ton truck, but it lists fluid levels for the 2500/3500 below the bulletin? so what gives, can I fill the axles to the fill hole or what? Bulletin lists 76oz front 122oz rear, is this correct?
