? About dash overlays
TST transmission Gauge install
Carchip or DriveRight
Guy's I am considering changing the dash in the Dodge and going with a Nu Image white face glow flame. They cover the stock back gounds on the speedo, tach, fuel and other gages for a new or different look. Question is, has anyone else done this? If so how bad was the install? Thanks
O. K
REALLY easy install :p
No really I wanted to run being the new Ozbornes was coming on (Or so I thought)
Easy to do
Run truck so It's at operating temp
Pull off dash surround
shut off truck and take note of needle position
Remove screws that retain guage cluster
remove plexi cover from guage body
Use supplied needle removal tool and remove needles
(Argh I forget if this step is or is not part of the instructions)
Peel off OEM coverlay
Install new coverlay
Install guage cluster leaving needles off and plexi cover
start truck and make SURE it's back up to operating temp (Even
bring needles with you and go for a drive)
Pull over and install Temperature guage needle pointing to where it allways and faithfully sits when up to temperature.
install Tach , oil , fuel , amps LIGHTLY and make sure they have a good read. if so Send them home
Go back home
clean plexi with L I N T FREE cloth and non harmfull cleaner (Better yet warm water and dish soap and you hand only)
dry it and install cover
install everything else
brag to your buddies
tell elderly that its a factory option
check out that cool epervessent blue lighting at night
chicks dig it so hit babies are us with windows down
buy a 3 pack of brandy new white hanes T~Shirts with nothing on them to accessorize with your new dash layout
wait until novelty wears off
find new bomb to install
