Slide ACF housing foreword to start with and bottom out the star wheel all the way foreword then back about 2 turns. this gives you a good starting point. Sliding the ACF gives you more Pre-boost fueling, once the turbo builds boost then the ACF arm will move forward and the governer arm will hit your new fuel plate. If it gives you too much smoke, all you need to do is back star wheel up a little, if you run out of throttle response or it feels tight and low in power then the star wheel is too far back, back the ACF housing about 1/16" to the rear and start over with your star wheel forward. It gets kinda repetitive but once you get it set right, you will notice it and the truck will run very well. Your stock auto won't like the #10 plate for very long if you use the power by the way. Do you intend to upgrade soon?
