Just an update on what I found. I picked up the new key switch and opened the box. Included in the key switch is a wiring harness and a relay. The not so brite idea of Dodge running the full voltage for the blower motor circuit thru the key switch. I found a couple of burnt connectors in the old key switch. The directions were not as clear as they could have been and I could install the kit in another truck in 1/2 the time. Before buttoning everything up, I checked reverse lights, blower motor, ABS dash light and air bag light. Everything work again.
