2nd Gen Non-Engine/Transmission ABS and brake light coming on sporatically
2nd Gen Non-Engine/Transmission Peeling Paint Again
Engine/Transmission (1998.5 - 2002) Fuel Pressure
While I am driving the brake and ABS light will come on for a few seconds and then go off only to do it again shortly after. I checked the brake fluid and it is only . 5" below full, could this potentially be causing it or is it something else?
Rear Wheel Sensor
This is a very easy job that you can do yourself. The part costs between $35. 00 to $40. 00 depending on you dealer.
It's located on top of your rear differential in the middle. It should be the only electrical connection.
Just disconnect the harness from the sensor, remove a reatining nut that holds a small metal shield which also holds the harness in place, and then remove the bolt which holds the sensor.
You'll have to twist it a bit and slowly pry it out. The entire process shouldn't take more than 15 minutes.
