2001 Dodge Ram 2500 4x4 with 5.9L 24v Cummins – ABS and Brake light on.
This is my "hail marry pass" before having to take this to a dealer. I have been trying to solve this for a month and I am at my wits end!
Current Situation:
· ABS and Brake Light are on.
· Brakes work correctly, firm but not grabby.
· ABS is disabled, no ABS. (Trust me, I tried it, no Bueno)
Here is what I have done, In Order:
1. Checked under the hood and in the cab fuses related to ABS, all good, continuity tested with multi-meter.
2. Replaced Passenger side Front Wheel Speed sensor. When doing that, found the caliper was frozen so replaced that, put new pads on front brakes and bled the system.
3. Replaced Rear Wheel Speed Sensor
4. Discovered Hydraulic booster was leaking replaced that and flushed power steering – hydro boost system.
5. Downloaded Service Manual and printed out all the schematics having to do with the ABS system and began testing resistance and voltages where applicable. As best I could tell all the wheel sensor OHMs where in spec, controller has correct power on the correct pins, no corrosion, no broken or frayed wires.
6. FINALLY bought a descent code reader and was able to pull several ABS codes, which indicated an issue with the CAB (Controller Anti-lock Brake) (Rear Isolation Solenoid malfunction.
7. Sent the CAB in to be repaired. They replaced a relay and a transistor, ran diagnostic and said it was good to go now. I got it back and reinstalled. No codes now, but still ABS and Brake Light on.
8. Replaced the Brake Pedal Switch (this is what turns on your brake lights and also sends this information to the CAB.
9. Tried forcing scanner to clear ABS codes, then restarted truck, still brake light and ABS light on, but scanner says nothing is wrong.
Other things to Note, Observations:
1. When turning the key from Off to Run, ABS and Brake Lights come on (with other lights) they go out (when I don’t have the parking brake set), and then 1.5 seconds later the come back on. That would seem to indicate to me that some sort of self-test has been run and is setting the light on.
2. If I disconnect the CAB (Antilock brake control module) the ABS light stays lit, BUT the Brake light goes out, which confirms to me that the brake light portion of this is not begin triggered by the parking brake switch, but by the CAB.
3. I even removed my Trailer brake controller on the off chance that it was somehow jacking with the system causing this, but that had no effect.
4. I have even stumped a Dodge mechanic, so I am really at a loss here.
The Question: After all of this what could be setting the ABS and Brake light on WITHOUT throwing any ABS codes?
And yes I have tried reading the codes and before the module was repaired, it was throwing codes.
Current Situation:
