Thanks
for the advice about the ABS system. As stated earlier when I got the truck back from the valve adj. the ABS& brake lights were on. :{ :{ You recommended that I check the vacum system. HDH and I checked under the weather strip at the hood and firewall,and a vacum line was broken in two.
Well we patched it with some rubber tubing and the lights went out.
: Thank you,
thank you,
thank you: .
This forum is the best
