Any body know why the ABS light would be blinking?? Just replaced ABS controller due to speedometer, cruise and tripometer went out. ABS light was on solid. Replaced the controller and everything works now, but ABS light just blinks on for 3 seconds and then off for 3 seconds. I suspect it is due to it "had" a code. Battery taken off for 30 minutes did not clear it and multiple ignition restarts do not clear it either. Check codes via on/off 3 times and it shows P done (no codes). Do we need to take it to dealer? Couple friends said you have to have ABS cartridge for scanner to clear them. Everthing works fine, just the blinky ABS light.
Questions/Comments?
Questions/Comments?
