I am having braking problems and could use some suggestions on how to disconnect the ABS. I have replaced the Hydraboost 2 times and both do exact same thing. I believe it is in the ABS system. Occasionally when moving very slow they pedal goes hard and you can't stop the truck. It has only happened at speeds less than 5 MPH. I have also flushed the power steering fluid. I now have the fuse out for the ABS and it hasn't happened yet. Only problem is the Speedometer trip meter and overhead computer doesn't work without this fuse. Is there anyway to disconnect the ABS without loss of everything else?
