Ol' Blue had this problem about 2 years ago. ABS and parking brake lights would stay on. The brakes worked fine. I finally found the problem was in my trailer wiring connector. The cap would not stay shut and water had gotten in it and started to corrode on the terminals. Mine also blew fuses when this happened. The interior light would not work and blew brake light fuses. Replaced the connector and things worked fine. I would suggest looking at any additional wiring you may have added to the truck. It was very frustrating till I found the problem.
later
Don
Ol' Blue "First of the first gens: 1989 D 250 Ice blue met. 5 spd 3. 54, 155,000, Banks stage III powerpack, 3. 5" straight exhaust, pump adjustments, "'Ol Blue Special" injectors.
1999 3500 4x4 Chassis cab Emerald green ISB 5 spd 4. 10 K&N Filter straight exhaust 9 ft flatbed WARN fenderflares,Let, 275hp injectors installed, boost and pyro gages, VA plug'n power and Practical Solutions boost module. Jacobs E brake. Getting ready to install Banks Power Pack TLC!!
May buy another one in 2009!!
Check us out at:
http://donstractorrepair. homestead.com
later
Don
Check us out at:
