Archived Abs help
Archived Transmission help in Houston
Archived abs help
I have a 1999 dodge 3500 4x4 with all wheel abs. On the scanner the left front wheel loses signal while driving down the road . I have changed the hub, abs wheel speed sensor , and the abs pump and controler and still the same thing . I have also ruled out the wiring by hard wiring the abs wheel speed sensor to the abs module and still loses signal. When it loses sigal while driving if at the right time when it is gone and you try to stop the pedal goes to the floor and cant stop
