Are you using a Chrysler DRBIII to check for trouble codes?
Have you tried resetting the CAB using a DRBIII?
Are you getting an ABS warning lamp on the instrument cluster?
Read through the following trouble shooting steps from the 1999 Chassis Diagnostic manual and see if anything jumps out at you. At a minimum I'd take the resistance measurements they specify to verify the wiring continuity.
Symptom: NO SIGNAL FROM LEFT FRONT SENSOR
When Monitored and Set Condition: NO SIGNAL FROM LEFT FRONT SENSOR
When Monitored:
Set Condition: 1. Speed greater than 13km/h (8mph) from one sensor.
2. No ABS activity.
3. No evidence of drivetrain accel detected.
4. No open sensor DTC.
5. No other DTC tests run.
6. Indicated speed at sensor under 6km/h (4mph).
7. Criteria 1-6 satisfied for 5 checks
POSSIBLE CAUSES:
CAB CONNECTOR OBSERVABLE DEFECT
LEFT FRONT WSS (+) CIRCUIT OPEN
LEFT FRONT WSS (+) CIRCUIT SHORTED TO GROUND
LEFT FRONT WSS (-) CIRCUIT OPEN
LEFT FRONT WSS 2-WAY CONNECTOR OBSERVABLE DEFECT
LEFT FRONT WSS DEFECTIVE
LEFT FRONT WSS OBSERVABLE DEFECT
WSS WIRING HARNESS OBSERVABLE DEFECT
TEST 78
Ignition Off
Note: Whenever a WSS - related trouble code is detected, a thorough visual inspection of the wiring harness must be performed.
Inspect the Wiring Harness and the following list of Connectors of the WSS Circuits and any related harnesses for any broken, bent, pushed out, or corroded terminals, or any chafed, pierced, or partially broken wires.
Rear Sensor (located on top of Differential); Chassis to Rear Sensor (Right Frame Rail just ahead of Axle); Chassis to Head Lamp/Dash Harness (Right Frame Rail near Transmission); ABS Module (under Hood left side under Battery Tray). Left Front Sensor (located below the ABS Module at Left Fender Side Shield); Right Front Sensor (above the Right Control Arm at Right Fender Side Shield).
Note: Refer to any hotlines or technical service bulletins that may apply.
Were any problems found?
Yes → Repair as necessary.
No → Go To 79
TEST 79
Ignition Off
Note: Trouble code sets when an intermittent Wheel Speed Signal is being
received at the CAB between 13 - 32 KM/H (8 - 20 MPH).
Inspect the Left Front WSS.
Is the WSS okay?
Yes → Go To 80
No → Repair as necessary.
Perform ABS Verification Test VER-1A.
TEST 80
Ignition Off
Disconnect the CAB Connector C2.
Note: Check connectors - Clean/repair as necessary.
Using an Ohmmeter, measure the resistance of the Left Front Wheel Speed Sensor Circuit at CAB Connector C2.
Is the resistance between 1000 - 1250 ohms for 2WD, or 945 - 1155 ohms for 4WD?
Yes → Refer to symptom CAB FAILURE VERIFICATION.
No → Go To 81
TEST 81
Ignition Off
Disconnect the Left Front WSS 2-Way Connector.
Inspect all Terminals.
Is any Terminal damaged, pushed out or miswired?
No → Go To 82
TEST 82
Ignition Off
Using an Ohmmeter, measure the resistance of the Left Front WSS Circuit at the 2-Way Connector.
Yes → Go To 83
No → Replace the Left Front WSS.
TEST 83
Ignition Off
Is any Terminal damaged, pushed out, or miswired?
No → Go To 84
TEST 84
Ignition Off
Using an Ohmmeter, measure the resistance of the Left Front Wheel Speed Sensor (-) Circuit between the CAB and the Sensor.
Is the resistance below 5 ohms?
Yes → Go To 85
No → Repair the open WSS (-) Circuit.
TEST 85
Ignition Off
Using an Ohmmeter, measure LF Wheel Speed Sensor (+) Circuit.
Is the resistance below 20K ohms?
Yes → Repair the WSS (+) Circuit for a short to ground.
No → Go To 86
TEST 86
Ignition Off
Using an Ohmmeter, measure the resistance of the Left Front WSS (+) Circuit between the CAB and the sensor.
Yes → Test Complete.
No → Repair the open WSS (+) Circuit.
VER-1A Verification Test
Ignition Off
Disconnect all previously connected Jumper Wires.
Reconnect all previously disconnected connectors.
Reinstall all previously removed Relays.
Ignition On, Engine Not Running
Replace any blown fuses/fuselinks.
With the DRB, reset the module.
With the DRB, monitor the Brake Switch Input while depressing and releasing the brake pedal.
Does the DRB reflect the actual position of the brake pedal?
Yes → Repair is not complete, refer to appropriate symptom.
No → Repair is not complete, refer to symptom BRAKE SWITCH CIRCUIT.
