2nd Gen Non-Engine/Transmission ABS Hydraulic Control Unit
ABS brake problems
Has anyone been successful in rebuilding the ABS Hydraulic Control Unit on a '95 with 4 wheel ABS. Dodge no longer supplies the part:mad: With the ABS "disarmed" I can't even get the front tires to lock up, only the rears. With ABS "armed" I can hear and feel the valves pop, but they do not cycle and the pressure pump doesn't seem to kick in. I'm thinking that I have a serious leak-by issue with the valves in the control unit for the front brakes. Brake pressure is bleeding off into the accumulators plus the pump isn't working. Need help fast on this one guys.
