I noticed that when I come to a stop every so often my ABS light will flash on and off quickly. It is so fast it causes you to question if you really saw something. This has happened to me about 12 times in the last 1. 5 years. It took about six times before I finally figured out what instrument light was actually coming on. I have checked my brakes and tested them and they appear to be fine. I have put the ABS through its paces on a back country road and it worked fine. Maintained the fluid levels and check for codes. I am not sure what the problem may be. Has anyone else run into this before?
