ABS Problem
leaking differential pinion seal
FASS Install
The brake and ABS light came on while i was stopped. Brakes seemed to work - drove home. Shut motor off and heard something running under hood. The motor in the HCU (Hydrolic Control Unit) was running with the ignition off. The only way I found to turn it off was unplug the large connector from the HCU. Brakes still seem to work OK but no speedometer or odometer.
Anyone have any ideas??
Bill Weber - 2004,2500. 4wd 6 spd
Bill,
It sounds like possibly an internal relay or solenoid for the HCU pump motor could have gotten stuck in the on position during a regular self test which only begins a speeds above 15 mph. Unfortunately, a Chrysler DRBIII scan tool would be needed to query the CAB for any trouble codes which could better pin-point the problem.
Good luck,
John L.
