Both my ABS and Brake lights came on today. The vehicle is a 96 4x4 with 4Wheel ABS. The lamps would go out after a shut down and cycle normallyat start-up but would come on again after getting the vehicle to about 20 MPH. The rear end would lock-up upon hard application of the brakes. I don't know if the front antilocks would function because I value my tires too much to find out.
Like a good TDR member, I booted the wife off of the computer, and read a few hundred posts and then went out and inspected the fuses, operation of the cruise, brake lights, and cleaned the rear diff sensor.
Well the lights now cycle normally at start-up and then stay out. Problem fixed-NOT! I applied the brakes and the rear end locks up. Again, I don't know if the fronts will function or not.
The vacuum is good and the brakes work fine other than the malfunctioning antilocks.
The most recent thing done to the truck was new OPTIMA batteries yesterday. A four mile test drive with the new batteries did not show any problems. The problems started today about a mile after leaving home. It is a wet snowy day.
Any ideas?
Any ideas?
