AC acting wierd
Door hinges
Steering coupler fix
OK guys, never had something like this. A few weeks ago when the defrost was on windows got really foggy. Had a funky smell almost like antifreeze. Never had to use it again tho. Not loosing any antifreeze at all and no visable leak. Been using ac alot now. Getting a foggy mist/vapor when the ac is on. Does not really smell just a visable vapor. Not wet, or smelly just bugs the carp out of me. Compresser cycles normally as always. Any Ideas on this ????? TIA, Mike
http://hometown. aol.com/hotshothauler/myhomepage/business.html 2000, CTD 3500, Air brakes on truck & trailer. 210,000 miles todate. DOT custom built sleeper unit. pulling a 40' G/N flatbed
2000 FL-70 Pulling a 48' low boy. 211,000 miles
Just bought another 92 D-350 215 P-Pump motor and NV 4500 180,000 miles 24 lbs boost all stock For now
YUP - you have a small leak in yer heater core or in a hose connection right at the core- it WILL get worse, count on it. You won't see coolent level drop cuz it will be topped of from the overflow container until it runs dry...
http://community. webshots.com/user/davison71 Early '91 250, 727 AT, 307 rear... Banks Stinger exhaust, intercooler... US Gear OD... Tweaked pump, upgraded radiator... MORE than a match for every new PS Ford encountered so far...
"Dura" WHAT? NOW I know where all those recycled beer cans go...
Which truck ? sounds like a R134 leaking from the evaporator. Had a simlar problem on a 94 Chrysler, AC system lost its oil due to a line leak, compressor went nuts and over heated/pressurized system and blew a hole into the evaporator. Smelled slightly like antifreez and had a light coat of oil on the inside of the windshield. AC continued to work until the compressor locked up(The mechanic put a can of R134A and some dye in it and said it would be fine #ad
, still haven't gotten reinbursed by that garage). Hope that this is not what is happening to your truck, it got real expensive.
1985 DODGE 1 ton Crew Cab(imported from California with no rust) W/8' box converted to 4X4 in 1999. Converted to a non-intercooled 1991 Cummins Turbo diesel & rebuilt 5 speed Getrag in 2001(wife can't drive a stick :). Freshly rebuilt and Balanced Cummins, Rebuilt NP205, Rebuilt Injector pump and tweaked, Matched Injectors, 3" New Mandrel Bent Exhaust,no muffler, Borgeson Steering Shaft, K&N Air Filter, 4:10 gears, limited slip rear end, 16" Goodyear GSA Wranglers, 16K Reese 5th Wheel Hitch,and LE Package, OEM Cruise Control, and a Sony CD Stereo. Next add-on some “Banks” toys ! If you want to know why I did all of this, 2 kids, one on the way and I can't stand F**d and Ch**y. Kyle Hoover ,Fruitport, MI.
One mechanic once told me R-134A is a carcinegenic (sp) (causes cancer in laboratory rats) but it's good for the environment!
89 D-250 LE 5 speed 3. 55 Limited slip, Banks Intercooler, 'Ol Blue Specials, K&N, Full Boar Muffler, 3" exhaust, Diesel Dynamics Stage 1 kit, Boost/Pyro. & 16cm2 215K miles.
Well the general deal is a bad heatercore survey says... ... Not trying to be cheep... . But can I bypass the heater core i. e. can I make a return route from one heater hose to the other. I hate to put stop leak in a cooling system... < unless someone has had good luck with that > The heatercore was replaced but out of warrantey now. Kinda sucks, my manual went with my other 92 I sold..... Thanks again guys, Mike <hope it dont get cold> Hurd
david , yes pipe out the heater core
put 1 hose into the other to bypass
core then see if thats it
a truck sitting in damp weather
not running or w/ no heater
will mist inside real bad also
1993 w350 ex cab, banks,nv 4500 in
open exaust, pw Injectors are in. Big rig flaps,tach in,. Its loud and goes ok, for a 93,Ham radio Call KK6dm
has ability to communicate any where in the world. Headliner shelf
5 antenna's
Yep its the heater core. Antifreeze on the floormat coming out the lower duck work right in from of shifter. Oh well... This sucks. Anyone know how much I have to tear apart to replace it ? Thanks again guys, Mike
