And be sure you do not buy anything that has leak stopper in it. That'll literally gum up the system.
Run the engine, turn on the A/C (dash vents, full fan), and 'set' the idle to about 1200 RPM, then add a can of freon. If the clutch starts cycling, then it was definitely low. If it's 85F or so outside, keep adding freon until it stops cycling; this will mean that you are getting just about maximum cooling.
Ideally at 85F or so, the low pressure should drop to, perhaps, 28 PSI and stay there with the clutch engaged. If you then turn the fan down, the pressure should rise to 45-48 PSI, and the clutch should disengage. This means you aren't taking enough heat out of the air to evaporate much freon. The clutch should also cycle on and off when it's cooler outside.
This is not how professionals set the system. But the local pro here always told me that the R134 systems just don't work very well and nothing can be done. However, since I've been setting mine so the clutch doesn't cycle when it's 85F or hotter outside, I've been able to drive a refrigerator when it's hot and humid.
Of course, I do have a leak in the system, since I have to add a can every week or three. But after 10 years and 235K miles, I expect the system to leak a little. Someday I'll find the problem.
N
