RJ2,
There are two drains coming out of evaporator. I'm not sure if there are two drain tubes exiting cab but there is definitely one. Look at passenger side fire wall ( I don't have book handy so if dryer is near firewall you found the drain).
As I understand it is short and the water will blow back on to firewall, some of the water seeps back into cab wetting the carpet. Check carpet under/behind evaporator/heater coil unit for wettness. A wet carpet can cause mildew smell.
Best way to tell if you found drain is turn on a/c, get under truck watch for water dripping down. When you find drain attach longer hose to it.
