T
TMax
Guest
Well after sticking my hand up into the cavity where the recirc door is located (I assume its the recirc door above the fan unit behind the glove box) I found the recirc door completely detached and blocking any flow through the system. I cut the little grate slats out and yanked the door out only to find it has broken off at the motor connection. With the door out, my ac blows great!
It seems that all my other doors are working properly for the moment... just holding my breath for the next door to go. I want my recirc to work but does anyone know how much it will cost to replace the door? It looks involved but it may now be too bad.
Chrysler should be footing this bill in my opinion just because I am probably the bazillionth owner this has happened to. #@$%!
