AC & OD wiring help needed
'92 Dash gauges acting "crazy"
Thin head casting?
Hi all,
91.5 W250, need some AC & OD wiring pointers
1/ Where do I wire an additional momentary switch (second-gen shift lever) to act in series with the factory dash mounted OD switch? This is the red-headed stepchild 91.5 with the OD control module behind the glovebox, and the truck doesn't have the normally used OR/WH wire on the factory OD switch.
2/ Looking at the schematics - there seems to be no AC relay and ECM pin used for the compressor clutch cycling, unless I'm missing something.
Relevant FSM wiring diagrams attached; thx in advance.
IIRC, YL\BK and YL\DB will be the wires you tap the 2 wires from the stalk into. That should activate the control module.
The compressor is not controlled by the SBEC on this one, it is a control on the return AC line to cycle the clutch off when it gets too cold. Are you trying to bypass the control for the AC?
BIngo, that did it on the second gen OD lever.
Alrighty. I did the following -
New gaskets & o-rings everywhere.
5oz oil in the compressor, 2oz in condenser, 1oz in evaporator & 1oz in drier.
Nitrogen in the system at 300psi and it held for almost 2 hours - no drop in pressure at all.
Ran 26psi vacuum on the system and it held for 2 hours.
Sucked in 40oz of R12 with the compressor cycling at 1300rpm + Max AC + blower fan on high.
Compressor OFF: 50psi low side and 220psi high side
Compressor ON: 25psi low side and climbs in a few minutes to 450psi high side.
Faceplate vent temperatures - 46-50 F
Raising the rpm to 1200-1300 turns the compressor OFF and high side drops almost instantly to 200-250psi
Why am I getting such high side readings, and is it normal for the compressor to be ON constantly until it de-clutches at 1200rpm?
Got mine finally fixed.
My damn fish scales were bad; there was a low charge in the system.
Vacuumed the R12 out, refilled 38oz R12 on a digital stand scale.
Vents are blowing 36F air with ambient of 87F and 88% humidity.
Pressures are 36psi low and 195 high.
Compressor cycles 4 times a minute for 10-12 seconds a time.
New clutch went in anyway...holds a dollar bill against the front grill even while the fan is freewheeling at idle. Old clutch didn't do that.
