OK, I've read thru every AC tread I can search on here and can't find an answer. The AC works fine around town, blower works fine, recirc door works good but when I take a longer trip out on the interstate say 30 minutes or more it starts acting up. I run it in "MAX" (recirculate) mode and it will suddenly turn warm and the blower doesn't seem to be blowing as hard. Yesterday I switched it back off of MAX and it started cooling again. I've had it stop cooling for 30 minutes or more before and after stopping for lunch it started working again.
This morning I tore into the dash and the recirculating door seems to work got and so does the fan motor. I pulled out the resistor block and checked it but couldn't anything good or bad with it. The air runs cold when it works properly.
I did notice one time the reciculator door stuck in the middle position once but worked fine after switching it on and off again.
We leave for Florida Friday and I need to get this resolved fast!
Thanks,
Bill
Thanks,
Bill
