B.G. Smith
06 3500 quad cab, compressor was replaced about 6 months ago, has been working great, usually have to cut back on fan and adjust the temp knob about 5 clicks when on the highway. All of a sudden I have limited cooling, I have to run it on recirculate to cool down inside, it will maintain the temp barely if i switch back to normal when on hwy. I pulled the glove box and can see the blend door lever/rod and actuator, it moves full stroke when I turn the heat knob full heat and back. I checked the suction pressure this AM with system set on max air and hi fan. Pressure is pretty steady at lower 20s, it never cycled off or went any lower. After it had run for a few minutes I checked the temps at the vents, mid 40s and a little higher on the far right vent. One time when I moved the temp controp slightly toward higher temp I did hear a noise like maybe the door was binding. Any ideas???? Thanks. bg
