AC/R134A Question
lift pump dead?
Driveshaft
After building a new Crew Cab, I need to know how much oil to put back in the AC system. I have replaced the condensor and the receiver/dryer due to the "accident". The AC system did not leak after impact, but because of the damage to the condensor I replaced it. So does anyone know how much oil to add to a R134 AC system that has had those two parts replaced ? I will be evacuating the system for about 90 minutes before charging with R134 A.
Kyle
If you did not drain the compressor it should not really need anymore oil. If that was an R-12 system that you are converting to 134 be sure and DO NOT put the synthetic oil in your system because it will mix with the mineral oil and form a hard gel and will plug the expansion valve. If it was an existing 134 system and you real want to add some oil I would just through in a oz. and call it good because you really should not have lost very much if any. If in doubt call a local auto compressor reman place and ask them. :)
