AC Recharge
Shudder Help
Need advise in fixing a block
It is the smaller of the two ports. It is located at/on or near the receiver/drier, the tank near the firewall on the pasenger side. If you have a set of service gages/hoses it will only connect to the blue hose adapter. If you have just the hose/connector for adding refrigerant it should only fit the low pressure side. bg
You might want to put a gauge on the high and low side first. I thought I was low on refrigerant, but it turns out the valve in the compressor that separates the high and low side was bad. I just got a reman and I have to get to the shop to have tham vacuum out the refrigerant so I can do the swap.
HTH,
Aaron
