Was cruisin to Spokane to go to the Rodeo yesterday and eventually notice I had no air/heat coming into the cab through the vents. If I put the selector on recirculate you could hear the fan howling away, if it was on outside air the fan could barely move any air.
When I went to fuel up I noticed every part of my AC system (high and low pressure lines) had about 1/8" to 1/4" of solid white frost on it
I had my stainless grill inserts in and removed them just in case they had anything to do with it. Then drove for a bit (now in town), it didn't take long to thaw everything out and get some heat again.
Here's my take on it:
It was really foggy (ice fog) and freezing outside. I had the defrost on. I wonder if the high moisture freezing air froze up my evaporator, blocking the air flow into the cab. The AC probably kept cranking away with the defrost on but the refrigerant wouldn't evaporate or warm up so eventually it froze up the whole system.
What do you think?
I'm no AC expert so I'm hoping someone can shed some light on this one for me.
Thanks in advance
Mike
What do you think?
Thanks in advance
Mike
