2nd Gen Non-Engine/Transmission AC Water Leak Fixed 1998 Dodge Diesel 2500
-98 Dodge 2500 Ram-
I believe I have fixed the A/C water leaking in the passenger side floorboard problem that I've had for a couple of years. Somewhere on this forum or another, I read that there is a drain on the firewall under the A/C dryer (passenger side in the engine compartment). I found the drain & added a 3/4" ID drain hose about 12" long & haven't had any water in the floorboard now for several days.
I'm hoping this is fix. I guess originally there was a drain hose but it must've fallen off.
Lynn
'98 Dodge 2500 (310,000 miles)
'04 Dodge 2500 (210,000 miles)
I'm not aware that Dodge ever put a AC drain hose on these trucks. I used a 1/2" hose for a tight fit and now can see condensate when running the AC. Never saw any drips prior to the hose install so I guess the water was running down into the insulation in the floor boards.
This is a needed item for any owner who has leveled the front end of his truck(the tube on the drain that is).
