Do the job yourself (nasty) and epoxy coat every surface except fin areas. Lay a bead of silicone seal to replace the foam strip it sets in and you will eliminate a potentila corrosion area. Buy the cowl filter that filters the incoming fresh air, and keep your floo vacuumed regularly to keep the evap from clogging with dust and holding moisture. Parts for the job are less than $300, and are available at most parts supply houses. The Dodge evaps are notoriously short-lived; use aftermarket.
