2nd Gen Non-Engine/Transmission Acceleration shutter and shake
Engine/Transmission (1994 - 1998) 94,1ton,4WD,Brake ?
Engine/Transmission (1998.5 - 2002) Injector Question
I have a 98. 5 24v I put the truck in 4wheeldrive for the first time since last winter road were slick in spots this morning. When I accelerate the truck shakes really band it does not shake when driven just under acceleration any idea what is going on? I put on a front leveling springs this summer other than that nothing has changed since last winter do you think the spring lifted the truck enough to put my drive line in a bad angle? Any input would be helpful.
kris
Your fuel filter is partially plugged and/or your lift pump is failing or both. Mine did the same thing last week, I checked the pump first, it's ok, changed the filter and ALL is ok. bg
Kris, check you front driveshaft u joints,and the ball joints/u joints on the steering knuckles. The driveline angle with the 2" lift shouldnt be enough to make it do that. IF there is a bad u joint ,it will aggravate it though.
only got it to about 30mph just does it when getting on it after a stop light roads to slick to really get on it.
