98 12V
Well, the mighty Cummins died yesterday morning. Smoke from the engine compartment, then the engine quit running.
Once I got to looking at it, the smoke was coming from the diesel fuel heater in the pre-filter. Looks like it's toast. As to why the engine quit, I'm not completely sure.
I tried pumping the primer button with the bleed screw open, I got some foam, but not the regular flow of fuel. With the pre-filter bowl removed, pumping doesn't seem to make the expected mess, cranking the engine doesn't cause fuel to pour out either. So, I'm guessing the mechanical lift pump died.
As for the fuel heater, I'm guessing that when it was left high and dry due to lack of fuel, it overheated and burned up.
So, any other ideas out there? Has anyone changed/rebuilt a lift pump? Do you have to change the whole thing, or can it be rebuilt? How the heck do you get at it to work on it? How do you replace the fuel heater? (I got the part out that looks like a plug, but there's another wire going to the top of the pre-screen that doesn't appear to unplug).
Thanks,
-cj
Thanks,
-cj
