If you have been following my progress testing the actron CP 9035. .
Well NOW I'M IN TROUBLE!!
I pulled the MAP sensor connector to SIMULATE a problem and kick out a check engine light.
I then put the scanner on to the truck and tried to find the problem...
It came back with NO PROBLEMS FOUND. . !!!
And this all the while the check engine light is GLARING ME IN THE FACE!!!
I had to do the 10 restarts just to get the light to go out..... but now I've got a code in Long term memory that I can't read or clear!!!!!
The reader is going back TOMORROW..... IT HAS NO USE FOR ME AT ALL!!!
Next question is ...
How do I CLEAR the code that I set on purpose???
AND which tool (under $300. 00) can read and correct Cummins ECM Codes?????
Let me know ASAP PLEASE!!!!!
THIS SUCKS!!!!!!
Larry
THIS SUCKS!!!!!!
Larry
