Add-on mirror
Plug location?
I need a brake controler..help!
I have done the searching, but everyone is either adding on tow mirrors that did not have them or extending regular mirrors. What I am looking for is a mirror I can add onto the bottom of my tow mirrors so I can see my 40' GN when making right turns. I have to adjust it right before I make my turn or I lose the trailer when rounding a tight one. Any help, suggestions or insight would be appreciated.
David
Can't help - would suggest to look at Camper World's website. They seem to have extensive online inventory. Otherwise, maybe I'd epoxy or rivet a round fisheye under the right mirror.
I went to a local big truck supply shop and bought two 6 inch wide angle mirrors with L brackets, one for each side. I always have my mirrors up in the wide position. I drilled a hole through the plastic housing around the mirrors in the lower inside corner and bolted the L bracket. The wide angle mirror kinda lines up with the arm holding the tow mirror. In this position if I flipped the mirror down the wide angle would be down.
The plastic around the mirrors is pretty tough. I have had the wide angles on for over three years and have not had any trouble.
Hope this helps.
Stan
