What amp are you using? Chances are the RMS wattage is much less than that. Take a look at distortion rate at that wattage.
The ampplifier can never pull more amperage than the fuse on the side of the amplifier.
I'll try to make it short. .
Take the RMS wattage rating and asssume 80% efficiency(it should be better than this)
w=v*a so . . w(1. 2)/12=amperage
so 400w RMS == 480/12= 40 amps. . You will not pull this amperage all the time. . under normal listening conditions you will use 1/4-1/3 of that.
the truth is that most vehicles operate at 14. 4v so electronics use less amperage.
If you listen to 400w of bass for any prolonged periods you will get hearing loss and a headache
... but cranking up your favorite song or jaming out for a half hour or so never hurt me much
usually the phone rings or SHE complains or you get home.
You have a 130 amp alternator . . I think. . handling instantaneous 40 amp draws will not be an issue and sustained draws of 20 amps should be no problem for our electrical systems. If you see lights dim on heavy bass notes. . check your grounds, be sure you have a large enough power cable to the amp and you may want a large capacitor.
Its likely that you will need at least an 8ga supply line. . if you really do pull 40 amps use a 4ga. use 10 or 12ga speaker wire. Solder any connectios you can and use as few quick connects(on the back of speake boxes) as possible. The name of the game in 12v audio is efficiency. thicker wire and soldered connections lose less voltage(it gets changed to heat).
Sorry so long . . hope it helps.
Mark
