Question
Kevin,
I went a similar route as you with my tank, and am about to hook it up (start transferring), but I have a question or two...
Background: I had one of the guys at work fab up and weld an aluminum tank, 88 gal, to fit in the bed and be removable. I'm running a spin on filter and transfer pump, plumbed into a welded in barb in the filler neck. The pump is capable of 5 gal/min, so it seems to pressurize the stock tank a bit while pumping (if the fuel cap is tight).
Questions: Do you have a similar capacity transfer pump, and if so do you have any problems with exhausting the air out of the tank (I can hear the hissing under the truck where it is exhausting thru the sending unit assembly while filling). I just want to make sure that I'm not hurting anything in the tank if I let the pump go full flow. Should I put an output valve in and choke the pump flow down some?
Thanks in advance,
Chris
