2nd Gen Non-Engine/Transmission Adding Mopar Fog lights to my 96
Engine/Transmission (1998.5 - 2002) FASS water seperator
2nd Gen Non-Engine/Transmission Heater Core Removal
Hey guys-
I want to put some of the factory fog lights on my truck. I was looking on ebay and they sell a new harness, headlight switch and fog lights from dodge. It says for 99-02. Anyone converted their early 2nd gen using that? What should i do and what do you guys recommend for wiring it up?
Erik
Question why would you want a dodge fog light kit? :{ I as have many others took ours out Oo. and replaced them with a good aftermarket light Like a PIAA or a HELLA lamp system. More light, better quality and I assume you will be adding a aftermarket switch much better system most aftermarket lights if bought in a kit come with relay's,wiring,switch ect and fit in the factory bumper hole at least it did in my 2001. 5 imho you will be much happier with a aftermarket kit same labor to install so buy a better product. my dodge fog lights lenses foged over in the first year I had them -Junk- good luck with your search just something to think about TOD
Only reason is b/c they are cheap compared to the piaa's
I have a reunel bumper with the fog light holes and want to install something in the holes. What piaas or other brands do you recommend?
erik
If you get that kit is has a different headlamp switch. Ours requires a relay and different wiring. The switch goes by the OD switch and on these it is part of the headlite switch. Our lite switch pulls out and this kit has a rotary switch. They are not interchangeable. I oerderd mine from the dealer for a 97 and got this setup, forced them to give me the 97 wiring kit and gave them parts from the kit I couldn't use.
