adding sales codes to the computer. how? where? who can help?
2004 2500 5.9 ABS problems that I CAUSED
Factory 17 inch forged aluminum Alcoa wheels
Truck is a 05 dodge 2500 5.9, it started off as a base model so everything is manual. This is what i have done. I installed a dash harness from an 05 that had power everything. I installed a floor harness from an 05 that had power everything. I installed all electric door harnesses in each door. I installed all oem electric window and electric lock actuators. I also installed power windows. Also installed is the key less locking module. This should be everything and i mean everything they I needed to convert from manual to electric. With that being said,
This is what i need
I need the sales codes that will allow my dealership to activate:
Power windows
Power locks
Power mirrors.
Lastly ill have them program the fob while they are in there.
Thanks for your help. Ive done alot of reading/lurking on this forum.
Update I believe i have gotten the sales codes, at this point im just trying to figure where to take the truck, (San Antonio) area or if i can just send the computer off and have the codes added
ive called several dealers to only be told that the options i want are not listed on their end. besides getting a computer from a vehicle with the options what other options do i have?
You will likely have to find someone with a DRB III scan tool to activate the features. A lot of the current dealer software has delete those functions and if they did not keep up with a DRB III they have nothing to work with.
