Adding TST and Code p-0069
Truck is sending codes,need help
Is my NVG 241 an HD version?
I installed the tst powermax for my 05 tonight. Everything went well, took my time. I got a check engine light and a p-0069 code. Did a search and I couldn't find anything on that particular #. Also had a 0237 which was turbo boost sensor. TST is awseome though, ran 4/3 highest. Thanks
My code database shows this for p0069:
GENERIC MAP - Barometric Pressure Correlation (DTC reinstated)
GENERIC Manifold Absolute Pressure – Barometric Pressure Correlation
Probable cause: Manifold Absolute Pressure (MAP) sensor, mechanical fault
05mxdiesel said:
thanks for the definition, but is that just from unhooking the map sensor?
Could be from possibly a loose connector, or maybe not disconnecting both neg battery terminals when doing the install
After about 10 key cycles, it should turn off the engine light, then see if codes come up again, As far the the 0237 code, I would call mark or danny at TST, could be related to the MAP sensor reading, (inconsistent)
